Zum Hauptinhalt wechseln
Model A1225 / Mitte 2007 und Anfang 2008 / Core 2 Duo Prozessor mit 2,4 /2,8/3,06 GHz
433 Fragen Alle anzeigen
Replacing hard drive and loading software
I have an IMAC EMC2134 that the hard drive is starting to fail.
I want to replace the hard drive before it totally fails. I see some good instructions on here but what I am not sure about is how to deal with the software. How do I get all my data and software off the dying drive and onto my new drive so I can boot up and get back going again once I change out the hard drive? I appreciate your help.
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Do you still have the original system installation disk? Do you have an Apple ID and account? Do you have an external hard drive enclosure or Universal SATA hard drive adapter? What operating system are you running?
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
One easy solution would be to get the Time Capsule to transfer everything in it's present state. Time Machine is basically the DeFacto when it comes to backing up your mac. You can get the cable I suggest in the link below to set up your internal drive before you replace it. Or you can buy a brand new Time Capsule. Find out more info here: http://www.apple.com/airport-time-capsul...
Another alternate good idea (since this is a dying drive) might be to convert the old drive to an external before you destroy it. To do this get this cable http://www.amazon.com/SANOXY-inch-Drive-...
In order
  1. Copy(drag) all of your files/apps to a folder like "My stuff"
  2. Create a recovery OSX drive
  3. Turn off your computer
  4. Swap out your old hard drive
  5. Turn on PC
  6. Reinstall OS X (cleans up old files)
  7. Plug your old drive back into the computer and copy all your old files over
Hope this helps!
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
If you have your old drive still connected when you setup the new drive with a fresh copy of the OS, the OS installer will migrate all your user accounts and files (apps & data) over to the new drive. But make sure you have a backup just in case
von
First, be carefull: make a backup of your disk before exchanging it. Nobody knows what can happen!
Before all, you have to connect your new disk to an external USB port. If the disk is naked, you need to purchase and install it in a SATA USB case. It is cheap and available everywhere on the Web.
Then, follow this Apple article:
https://support.apple.com/en-us/HT202796
BE EXTREMELY CAREFULL TO CHOOSE THE RIGHT VOLUME TO INSTALL THE SYSTEM ON, OTHERWISE, ALL YOUR OLD DATA WILL BE ERASED.
Once the new system installed on your new disk, make the HD exchange between your old in your Mac and the new in the external case. Restart keeping the key "alt" down. A choice of starting volumes will be displayed. Choose the new one and follow the Welcome instructions of the new starting system . When you will be asked to migrate your old data from, choose "a Mac, a Time machine Backup or Startup disk".
See also these Apple instructions:
https://support.apple.com/en-us/HT204350
Bewertung 0
Antwort hinzufügen
dengelbert wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 199
