Zum Hauptinhalt wechseln
15.6 inch display. Identified by Model Code: NP470R5E-K02UB. This device was released August of 2013.
9 Fragen Alle anzeigen
Do not attempt keyboard replacement.
Hey everyone,
This isn't so much a question as a word of advise. Do NOT attempt to replace the keyboard on this device without purchasing a new palmrest/top case as well. The keyboard is held in by what looks like plastic rivets, and is VERY difficult to replace on your own. I've attempted a keyboard-only repair a few times, and I won't let it happen again. It takes much too long to tear off all the plastic rivets and glue the new keyboard down, and you end up with a less than satisfactory repair every time.
Ist dies eine gute Frage?
Bewertung 4
1 Kommentar
Where did you order the palmrest/top case that you recommended. If you could provide the part number, that might be helpful if a future repair is required by someone who reviews the post.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
I had the same experience. Had to completely disassemble the laptop to get to the keyboard, then cut off the plastic rivets with a box cutter to remove it. Well, OK, my student worker did. I supervised. It's nice to have minions. It did turn out well but took a few hours.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
hi brianstrech,
how did you guys glue the keyboard back?
von
Antwort hinzufügen
Max Rysdon wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 1,573
