Zum Hauptinhalt wechseln
The Honda Element was a compact crossover SUV based on a modified CR-V platform, manufactured in East Liberty, Ohio and offered in front-wheel and all-wheel drive formats
How to repace ignition coil
how to replace my ignition coil 2003 element
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
I Have The Same problem for 2005 Honda Element
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
This does not have a single coil instead it has coil packs on top of each spark plug . They are easy to change out usually held down by a bolt and once removed you disconnect the wire harness and pull the boot. Did you get a error code on the OBDII or why are you wanting to change the coil . A misfire will be coded for you and will tell which one needs to be replaced Usually a po300-304 . you will need the fireing order to determine which coil pack to replace. when doing the replace its a good idea to replace the spark plug at the same time . Hope this helps
War diese Antwort hilfreich?
Bewertung 4
1 Kommentar:
there may be a cover over the valves that hides the plugs and coil packs depending on the year of the car
von
Antwort hinzufügen
pjbordeau wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 1,213
