Zum Hauptinhalt wechseln
Reparaturanleitungen und Support für das Honor 6, ein kostengünstiges Smartphone von Huawei, das erstmal 2014 auf den Markt kam. Es verfügt über ein 5" 1080p Display, einen Octa-Core Prozessor, sowie eine 3GB RAM.
20 Fragen Alle anzeigen
Why after removing my charge mobile gets switch off
I have huwaei honor 6 h60-l04 and today suddenly I hve facing a situation.. While I m charging my phone is getting charged and working.. But if I m removeing from charging aftr few minutes it automatically gets switched off and while trying to on it by pressing power button it just looping the boot screen for infanite amount of time.. Then again when I m putting it in charge its working..
Do u have any idea what happened to it...
Plz reply..
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 12
24 Kommentare
yeah,same problem i faced and ichanged my battery now its work fine,better change ur battery
von
seems your battery needs a replacement
von
yeah, i changed my battery,now it works fine.
von
Where can I get a new battery
von
In service center you can get.
von
19 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
14 Antworten
Gewählte Lösung
me too since 2 weeks ago :(
why does almost the honor 6 user faced same problem?
-__-
War diese Antwort hilfreich?
Bewertung 3
10 Kommentare:
dah ade solution tak? kene same gak.
von
It is battery problem.Service center charged me 1500/- for battery replacemnt.Now it works fine.
von
here i'm being charged 2800/- for battery replacement
von
me to..same problem. what u mean off 1500/- or 2800/- is amount in rm or rp ?
von
hi,
its for battery replacement
von
5 weitere Kommentare anzeigen
Hilfreichste Antwort
try to change the battry
Bewertung 3
It is usually a sign of a failing battery. If it works when connected to a charger but shuts off when the charger is removed then replacing the battery should fix the issue. Your battery currently may be able to turn on the device but does not supply enough power to fully boot the phone when it is not connected to a charger.
Bewertung 3
2 Kommentare:
yeah,its battery problem, for me also they charged me 1500rs/- better change your battery.
von
nandhini stop spamming your answer everywhere
von
Hi Nandhini,
My mobile Honor -6 also facing the same issue. Could you please help me out for the solution ? ?
Thanks,
Sathish
Bewertung 1
1 Kommentar:
von
Bewertung 1
1 Kommentar:
1500 /- mean rm 1500 charge for change the battry only?
von
ok,, and i asked one of service shop they told me to change motherboard its cost me rs:7500/- what to do ??
Bewertung 0
10 Kommentare:
Did they mention what was faulty on the motherboard? I would try to find a multimeter to test your current battery's voltage. Or did they try to power your device on with a different battery or bench top DC power supply? If they did not I would still test your current battery or try a new one. Let me know and maybe I could help out. I do not trust many service centers as most just try to sell you a motherboard cause they don't know how to repair them. They make more money that way too. It could be a power issue on the motherboard but from your description it sounds more like a failing battery.
von
no just i went to service center and i explained that While I m charging my phone is getting charged and working.. But if I m removeing from charging aftr few minutes it automatically gets switched off and while trying to on it by pressing power button it just looping the boot screen for infanite amount of time.. Then again when I m putting it in charge its working..
then they informed that motherboard problem so have to change that but its cost me Rs:7500/- they said.. i got shocked.
They didn't check my mobile also.JUST they told verbally.
Can you help me next what should i do?
von
my mobile honor 6 is inbuilt battery...
totally am confused.
von
Yes the battery is inbuilt but you may be able to view information about your battery and its statistics without removing the battery by opening your phones dial pad and typing in ##4636##. I will provide a link that helps troubleshoot battery issues in an Honor 6. In the link provided there is the information to guide you through this battery information menu, just locate the section titled ACCESS THE HONOR 6 BATTERY INFORMATION. Let me know if you do not have access to this menu and if this link does not help solve the issue.
https://www.orduh.com/fix-huawei-honor-6...
von
i just typed in dial list ##4636## then i dial but its shows call cannot be completed. what to do now?
von
this is screenshot of i applied that code then what should i do?
Bewertung 0
This image only i got after download.then what should i do?
Bewertung 0
8 Kommentare:
With the Battery Doctor app open on the page you provided a screenshot of, could you tap on the Save icon at the bottom. When this screen is displayed find the area that has the temperature, Voltage, and Capacity readings. Now tap on that area to open a battery info page. If you could take a screenshot of this page and post it or at least let me know what it displays for the Health Status, Battery Voltage, Current power, and the Battery Temperature that would helpful to determine if your battery is in good working order.
von
Battery Temperature : 31.0c, voltage :4.3v ,capacity : 3000MAH,health status:good,battery type: Li-poly.this what it shows in battery doctor.then what should i do now.
von
there??? shall i flash my mobile?? r what should i do???
von
Have you tried doing a factory reset on the phone yet? A factory reset may help if it is software related. Did this start after a software update? I have seen others with this phone experience the same or similar issues. With some it happened after an ota update. Some were able to fix the issue with a factory reset and some have taken it to a repair shop and found the battery to be the issue. Let me know if you have tried a factory reset or if you need help doing so.
von
can you suggest me shall i do factory reset ???
von
3 weitere Kommentare anzeigen
Same issue I am also facing, Huawei service center people told me to replace motherboard. However Phone works fine when connected to power. Please help!
Bewertung 0
1 Kommentar:
von
Hi Nandhini,
I also have the same problem. Please let us know which service center you have solved the issue.
Regards,
Suresh
Bewertung 0
1 Kommentar:
It is battery problem.Service center charged me 1500/- for battery replacemnt.Now it works fine.actually which city r u from?
von
Same issue with me also.
when i am trying to open any application it gets switched off and and goes into the loop mode. but it work fine when it is on charging. i have read the previous comments so what exactly the issue is related to ?
it is a battery issue or motherboard.
Bewertung 0
4 Kommentare:
von
Thanks Nandhini :)
von
I have Huawei honor 6 H60-L12, I went to huawei service center and they said its a board issue, they refused to check the device as I bought it thru aliexpress and I have to send it back by post to China to be fixed? Is this ok!!! What is the warranty period for huawei honor 6? Is there global policy for warranty months period? Please help!
von
Hi,
Actually what issue your facing and if its battery issue better change your battery alone, then it works good. and honor 6 warranty they mention while you buy itself and its one year.
von
Hi i am using Micromax AO5510 Mobile and recharged my battery and charged my battery to full and it was working when the battery comes to 35% the mobile is showing battery slow and automatically switch off the mobile what will the problem
Bewertung 0
Have you tried removing then putting back in the battery?
Bewertung 0
1 Kommentar:
I have samsung galaxy note 3 neo
Plz reply..
von
Anybody help me i got this problem ,, can go for service center ?
Bewertung 0
Antwort hinzufügen
nandhini wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 33,793
