Zum Hauptinhalt wechseln
Repair guides and support for a wide range of welding machines.
15 Fragen Alle anzeigen
it just shut down, no power
it's a campbell hausfeld welder model ws28000
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Can you hear it hum ? If not you probably blew a fuse in the unit. Hopefully you checked the breaker panel to make sure you didn't trip a breaker. If you do hear a hum ,you have power . It may be you lost your ground , but if you are not familiar with high voltage I would get someone who is.
War diese Antwort hilfreich?
Bewertung 1
It could also be that the thermal overload has tripped. With cheaper stickwelders, they over heat a lot. When this happens, let the unit cool down and the thermal overload reset.
Bewertung 0
Antwort hinzufügen
Horace Salik wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 12
Insgesamt: 313
