Zum Hauptinhalt wechseln
Reparaturanleitungen für Golfmobile
494 Fragen Alle anzeigen
I have a 1986 club cart
I bought a club car 1986 with the flat head motor it was running had a little nap to address it around the block and it just quit you push the pedal the motor still turns but dont start seems like it lost compression
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
First thing that I'd check is to see if it's getting fuel. Check the fuel filter as well. You'll need to narrow down if it's a spark issue or a fuel issue. Fuel issue= take hose off at carb or if you can see filter and it's a clear type, look to see if fuel is moving while someone try's to start it. Spark issue= Use a pair of pliers with rubber or insulated handles and pull off the spark plug wire and hold it about 1/4 inch off of the head or block. Have someone crank it and see if spark jumps across.
See if one of those are the issue. Good luck.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
with the 1986 club car flat head motor I took the head off the motor you can push the piston down with your hand but it won't come back up when you turn the motor I need some type of diagram or video of how to take and get to the piston rod and camshaft
von
Antwort hinzufügen
Tim wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 159
