Zum Hauptinhalt wechseln
Repair and disassembly guides for doors and windows.
Trouble with glazing and window repair
Hey, guys.
I'm not sure whether this is the right thread or not, but I'll ask my question here anyways. Let me know if should be moved. So here's it.
My small Sydney home has just undergone an exterior renovation. I'm a DIY-er and I've taken care of most of the small fixes around the house, but I'm not so good with the windows. I've watched a couple of tutorials on the Web and asked around a couple of friends and my quest has taken me to the conclusion that glazing is a rather difficult task. I'd love to get another opinion here about whether or not I should try to do it on my own . Whatever your answer is, please provide me with some additional info on the topic, reference websites, guides and book suggestions are all welcome.
Cheers,
Mark''
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
Hi,
What material are the frames made of?
von
Hi jayeff, they are wooden.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I myself have a century home and with it still have a few windows, that I just haven't got around to replacing ,that require glazing. I find that when I do them its always best to have lots of time an patients. Its also prudent to have new glass on hand to replace the one that inevitably breaks .doing 3 sides is also a good idea i find leaving the bottom strip of old glaze in place till the other 3 sides are puttied in makes the job faster and your less apt to drop glass. I'm not sure where your located but here in Canada I like to use Dap Latex Window Glazing. I use a caulking gun now instead of the putty knife approach. I tape the window off and that way it makes a neater job. I usually give it a day to cure then go back and do the last side the next day. Just be carefull when removing the old putty and clean the surface the best you can before applying the new putty. Hope this helps and good luck with your windows
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Hi Jimfixer, thanks for the answer. I'm from Sydney. I might try this technique out and let you know how it goes.
von
Antwort hinzufügen
Mark Taylor wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 470
