Zum Hauptinhalt wechseln
Das Apple iPhone 5s wurde am 10. September 2013 angekündigt. Die Reparatur dieses Geräts ist ähnlich wie bei den Vorgängermodellen und erfordert Schraubendreher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA mit 16, 32 oder 64 GB in silber, gold und space grau.
3530 Fragen Alle anzeigen
screen cracked and phone body bent
I dropped my Iphone and the screen is shattered. all functions still work as I have a really good screen saver that is not broken so I think I can just replace the glass screen. However, the body of the phone is bent so it is no longer flat. once I remove the screen will I be able to bend this back into place so the new screen will fit properly?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
4 Antworten
gövde eğilmiş ise anakart muhtemelen bozulmuştur, yeni bir telefon alman bence daha sağlıklı olur
War diese Antwort hilfreich?
Bewertung 0
Yes, you can bend back Iphone frames. Look for youtube tutorials.
BUT, bending metal will decrease strength and could break it. So be careful.
Bewertung 0
you should be able to bend it back as long as it does not affect the circuit board and as long as all clips for the screen and screw hold line up there should not be a problem. How badly is the phone bent?
Bewertung 0
hello from experience I can say that separate the display from the glass is not easy if you have not experienced a minimum and you can buy for 50 € + display glass. while for the homes it is very folded it is difficult to bend, then you should take it back € 30 million without wiring and comprehensive € 45. to make these interventions there are guides on the site but you have to be a little 'expert and have manual skills and courage. good repair
Bewertung 0
Antwort hinzufügen
boatswain2385 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 4
Letzte 30 Tage: 8
Insgesamt: 3,128
