Zum Hauptinhalt wechseln
Das Apple iPhone 5s wurde am 10. September 2013 angekündigt. Die Reparatur dieses Geräts ist ähnlich wie bei den Vorgängermodellen und erfordert Schraubendreher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA mit 16, 32 oder 64 GB in silber, gold und space grau.
3530 Fragen Alle anzeigen
Only accepts certain chargers and drains battery quick
Hi,
I have a 5s that was returned by a customer. Originally he bought it and messaged me saying it was completely dead, I went to his house and tried a different wire and then he told me to change the battery anyway as it was draining fast. I changed the battery and the same thing happened again except the other wire didn't think this,
I disconnected/reconnected the battery and it turned on (with 80%+ battery) so I am thinking maybe it wasn't connected right.
Now I have the phone back and I have refunded him and I am doing more tests. The phone doesn't charge with certain chargers, I have a 5c that charges with all of them. I'm unsure of which are genuine and which aren't but I believe it won't charge to genuine ones
The battery drains fast in standby mode
Is this damage from using 3rd party chargers? What can I do to fix?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
What apps does he use on his phone? Have you checked charger port if there's any build up of dust / debris? If there is, use a toothpick to clean out the charger port, because if the lightning charging cable does not plug in fully into the port, some chargers will not charge properly.
It's surprising that sometimes a blocked up charger port can actually cause a phone to short and drain power.
For example, on a samsung phone, it would brick the software because pins were probably bent and shorting on boot when the charger port was blocked. Once I cleaned it up I had to reload the firmware (software / operating system) on the phone to get it working.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
The phone has been reset with no apps. The charger port is clean
von
Antwort hinzufügen
James Carter wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 6
Insgesamt: 250
