Zum Hauptinhalt wechseln
The Nikon Coolpix S33 Waterproof Digital Camera B00T85PKD0 is designed as an all purpose camera that is waterproof, shockproof, and freeze-proof.
Why won't my Nikon Coolpix S33 turn on?
My camera will not turn on. I'm not sure if it is a battery problem or something else.
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
2 Antworten
Hey,
You are going to want to make sure that the battery is inserted properly into the device, the best way to check this is to see if the battery cap is clicked in properly. If this is not the case, then you might have a drained battery and should charge the device without any interruptions.
If the two solutions above have not worked, check the following page for more possible problems that could be causing your camera to not turn on and their solution:
Nikon Coolpix S33 Troubleshooting
War diese Antwort hilfreich?
Bewertung 0
The battery is no good or its not charged.
Bewertung 0
Antwort hinzufügen
Kacie Lemos wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 26
Insgesamt: 5,130
