Zum Hauptinhalt wechseln
Repair guides and troubleshooting support for Leapfrog LeapPad3 Learning Tablet
My speaker and D-Pad are simultaneously not working.
The speaker is fuzzy and sometimes does not have any sound at all. Only one or two of the directions on the D-pad are registering. I'm looking for a way to resolve the issue without replacing either component.
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar:
My Leappad won't let me press my name on my Leappad.
von
Einen Kommentar hinzufügen
1 Antwort
I had the same problem with my LeapPad3. Always turn off your device and turn it back on again, as this can solve a few issues your device is having. If this doesn't work, you will have to remove the back cover of the device and tighten the cable connecting the speaker to the motherboard. If that doesn't fix the problem, then you may be forced to replacing the speaker itself. There is a guide 'here' that can help you through the process step-by-step. Good luck!
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Matt Irvine wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 6
Insgesamt: 365
