Zum Hauptinhalt wechseln
Das Apple iPhone 5s wurde am 10. September 2013 angekündigt. Die Reparatur dieses Geräts ist ähnlich wie bei den Vorgängermodellen und erfordert Schraubendreher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA mit 16, 32 oder 64 GB in silber, gold und space grau.
3530 Fragen Alle anzeigen
Frage geschlossen
Unidentified Internal Phone Part (iPhone 5s)
Upon opening my phone up to replace the battery, I pulled a little too hard with the suction cup and my phone popped open, detaching the home button cable and then sending the part in the image attached flying out of it. Nothing was damaged and the phone is working fine, but I cannot figure out where this part goes. (There is a slight chance its from something else I was working on earlier but I wanted to check with people on here first to be sure). If anyone recognizes the part and could tell me where it goes that would be great!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
That goes on top of the home button connector. You will see two notches near there where you put that metal clip in (Three notches actually so you don't put it in the wrong way).
You're lucky you didn't rip the home button cable when opening your phone. Next time don't put too much force when prying up the display assembly up. The home button cable needs to be detached with it's clip removed before you lift up the screen too much.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Thanks a bunch! I'll be more careful next time. Would of sucked if I opened it up to fix the battery and then broke the home button in exchange haha
von
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 55
