Hi Marty.
How to fix a split Fusion Drive
This is a support document from Apple USA.
There is a problem with your Mac, so it's worth a try.
The backup will be in the external SSD.
Another way is to kill a small built-in SSD.
Boot from the recovery area and format it with Disk Utility. Leave as it is.
Or start up in target disk mode and connect to Windows 10 machine.
Hit the Disk Part with the power shell with administrator privileges.
List Disk
Find the small SSD number of your Mac.
Select Disk * * is the target number.
Check well and type crean.
Although SSD exists physically, it does not exist ethically.
The disturbing person disappeared.
Good Luck
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
0
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
