Zum Hauptinhalt wechseln
Das Apple iPhone 5s wurde am 10. September 2013 angekündigt. Die Reparatur dieses Geräts ist ähnlich wie bei den Vorgängermodellen und erfordert Schraubendreher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA mit 16, 32 oder 64 GB in silber, gold und space grau.
3530 Fragen Alle anzeigen
iPhone 5s Battery drains fast, motherboard issue
I have an iphone 5S with battery problems, the battery drains fast even if the phone is in rest mode. Ι changed battery but does not seem to work so i think that the problem is in other part of the phone, then i tried to test all the phone parts, i removed the charging port, removed the lcd and and i left the phone for some hours and i saw that in this case the battery drains fast two. About 10% in an hour. I think the problem is in the motherboard, i would appreciate if someone could help me how to check the motherboard and what to do. Thank you so much
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Do you have an external DC PSU that you can power the phone from? If you do you can measure the current draw of the phone.
Also, if you have a Mac, search for a program called "coconut battery" it will help you diagnose whether your battery is in need of replacing.
I have also found that more often than not, when you replace a battery on a 5S, you also have to restore the phone - and no back-ups allowed.
Those are some things to consider before you just dive into the motherboard
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
I replaced the U2 ic, i was very carefull i thought i made good job but after this iphone stuck to apple logo. But iam sure i made great job, no other capacitor removed near U2 ic and i lined the chip perfect. Maybe the chip i bought is low quality and does not work. Do you know any site to buy high quality chip?
itunes does not regognize the phone any more
von
Also for info the windows version is pretty much called 3UTools.
von
@benjamen50 I'm starting to think you have stock in 3uTools ;>).
Kidding or course...I tried so many different tools but I agree that 3uTools is the best.
von
Antwort hinzufügen
johnfl21 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 875
