You didn't give me much to work with, such as does water start to enter. Has it ever run?
First thing to do is to unplug it for 5 minutes to allow it to reset.
Most Frequent Causes for Washer won't start
Cause 1
User Control and Display Board
To determine if the user control and display board is defective, try pressing the buttons on the control panel. If some of the buttons work, but others do not work, the control and display board might need to be replaced. Additionally, if the display is not working, check the power to the user control and display board. If the user control and display board has power, but it isn’t working, replace it.
Cause 2
Timer
The timer is frequently misdiagnosed—before replacing the timer, first check all of the more commonly defective parts. To determine if the timer is defective, consult your washer’s wiring diagram and use a multimeter to test the timer for continuity.
Cause 3
Line Fuse
The line fuse blows if the washer circuits are overloaded. If the line fuse blows, the washer won’t start. To determine if the line fuse is at fault, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. In addition, you should investigate and resolve the problem that caused the fuse to blow. Check for shorted out components such as the wires, motor, or drain pump. If you don’t resolve the underlying issue, the new fuse will blow too.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
2
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
8 Kommentare
At what point does it stop? Is it filling?
von mayer
It stops after a minute or less
von jasminli
It stops during the wash cycle
von Ocean Blue
My L.G. W.M. stops after it starts washing cycle and gives error code as de.
After complaining the authorized mechanic came, opened and said that the fuse is gone. He then fixed it and took his money. Now the machine does not stop when the door is opened in the middle of the Washing/Rinsing/Drying cycle. I have called the mechanic now four times and he is avoiding. P.K.
von Prabhakara K
Lg washing machine 7kg inverter washing machine 1 time start then stop after no start
von yogen.yd57
3 weitere Kommentare anzeigen
