Dryer just stops, no error codes
In the middle of a drying cycle, the drum will just stop spinning. No error codes pop up and the timer remains where it stopped. Pushing any buttons results in beeping, and the dryer wont start again unless you let it sit for a while. The lint tunnel/passage in the dryer is clear, and the external ducting appears clear as well. What should I look at next? Thanks.
Ist dies eine gute Frage?
1 Kommentar
It may also be worth noting that someone before me had recently attempted to clean out lint in the dryer and managed to unplug one of the moisture sensor bars. However, even after making sure these were both plugged in, the problem persists.
von John Doe
