Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
Why is my external speaker no longer working after housing replacement
I had to replace my iPhone 6 housing, so I decided to use a custom housing. I successfully to replaced it but today the speaker you would use to play music stopped working. Could there be an issue with he fled cable eventhough all of the other components on the cable still work or could it be the speaker itself.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Definitely check the connector first - be very careful with it because contacts are very fragile.
Hard reset ( Home and Power button together) could help as well in case that one of the applications still "hold" that service
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
On the flex cable there is one small tear that is less than a millimeter but could that be the issue
von
Yep that is exactly the cause.
The small tear starting from the right side of the ribbon flex cable to the dock connector.
That is one or two or the circuit lines in the ribbon cable that provide the connection to the bottom loudspeaker / ringer / speaker.
You probably need to be more careful when prying the dock connectors.
I pull a bit but not where it looks like it will tear I use a prying tool to pry opposite of the easy to tear spots I usually do them last if you know what I mean.
Its kind of a bit hard to explain.
von
Sometimes custom housings have plastics covering the speaker holes which you can see at the bottom on the right of the charging port just grab a needle and poke one see if you get sound.
Bewertung 0
Antwort hinzufügen
Robert Hayek wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 89
