Zum Hauptinhalt wechseln
Die zweite iPad-Generation mit WiFi, GSM und CDMA Modellen. Einige Modelle wurden noch einmal aufgepimpt vor dem iPad 3. Die Reparatur ist schwierig und verlangt Hitzezufuhr und Hebeln.
730 Fragen Alle anzeigen
Sound and other issues after ipad repair
Hi,
I'm a relatively experienced device repair technician. I've done a few iPad digitizer and it never fails, every time they comes back. Sometimes it's for ghosting, which makes sense. But now for the 2nd time, I've got one back where the sound isn't working. The ringtones all work but media and apps have no sound. How could doing a repair on the digitizer have anything to do with sound? Have you guys seen this before? Any fixes? Customers seem to get extremely angry when I can't fix this, and I honestly have no idea how to.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Very strange, can't say i've had this problem before. Are you sure you're not damaging the volume/power cable when removing the screen?
If you follow the guide here on ifixit exactly, you should not have any problems.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
It is a possibility as the top right of the iPad 2 has the volume button and power button cable flex being exposed to the point where you can cut it if you don't lift up the glass properly.
If that cable is cut, you won't be able to use the volume buttons or the switch near the volume button. It's usually to toggle the mute for the iPad.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Michael H wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 55
