"wait" flashing after turned on!
Device is flashing wait, after i turned on it.
Sometimes you can change mood from photo to video.. but when you push the record buttom it is again flashing wait and then it turning off automaticly..
Ist dies eine gute Frage?
2 Kommentare
hi i wanted to inform you..
it was all about hardware..
i used the cam on my handbar that is why i damaged the coneection between lens and cam..
thay changed it for 50$
it is ok now..
if you will use it on bike pls use it on your helmet!!!
von ferhatucankus
Hello!!! Sony HDR AS30 did not work when REC bottom pushed! On screen blinks text WAIT WAIT WAIT!!! Problem fixed.I took battery out of camera. Next i opened camera(two screws).After i unscrew lcd module screws(two) i open cameras body(motherboard and lcd module sides)and unplug lcd module side from motherboard.Than i check all the flex cables(lense cables-big with lense and motherboard and small which connects with motherboard)and i saw that two of them are not perfect in socket(sorry i'm Latvian.If there are some mistakes in english,sorry).I reconnect lense cables both side of cable and small cable also (very carefull!!! Be aware!!!).Than i returned them back each-very carefull and in perfect position!!! Than i put back lcd module panel to motherboard also connect flex cable and screw both screws back.Than i put in battery and mini sd card and SO!!! Camera works perfectly!!!! Push record and all is working perfect!!!!! Cameras issue was flex cables which were not in their places perfectly!!!
von patrx
