Zum Hauptinhalt wechseln
Dritte iPad Generation mit Wi-Fi, Modellnummer A1416, erhältlich seit dem 16. März 2012. Die Reparatur erfordert Hitzezufuhr und vorsichtiges Hebeln.
Digitizer does not work
Hi have changed the back light IC on the logic board. The back light issue is solved after replacing the back light IC but like always it is some or the other with ipads .
After hooking up everything the touch doesn't work, I have used 5 different digitizer to see if it is digitizer issue but neither one works and I dont know what could have happened .
Please suggest.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
[image|806990] I hope this will work
von
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
I suggest you knocked something off the board or used too much heat or damaged the connector. Look for missing components, balls of solder which do not belong, and/or any type of visible damage.
Next look at the schematics and troubleshoot touch circuit.
EDIT:
@touchwireless in the red circle most to the right in your picture, there seems to be a small component, possibly a resistor bridging two capacitors C3106 and C3108. Those 2 caps are on an important line shooting out from a touch IC. Remove that component and see if that solves it. Unless it is an artifact from the picture...
Here, that small guy in the middle of this circle, the only vertically positioned component:
War diese Antwort hilfreich?
Bewertung 2
12 Kommentare:
I am not good at soldering this is something I am trying to do and this is freeking me out
von
what if i have used too much heat will the ipad still turn on ?
von
It should, so that you be careful. If you apply unnecessary amounts of heat to remove the shields, you kill the phone. Practice with scrap iPhone 6 boards first. They are a special breed when it comes to shield removal.
von
how should i know if thats the overheat issue
von
is it fixable? if not I ruined the customers ipad
von
7 weitere Kommentare anzeigen
here is the pic for the logic board I worked on
Bewertung 0
1 Kommentar:
I'll look at my schematics and get back to you. It does seem like you bridged something unless this is due to the bad image quality.
Can you add a high-resolution close-up picture of the area circled in red?
von
Heading text
Bewertung 0
2 Kommentare:
I hope this will work for you Rany
von
Yes something is not right. You seem to have a component shorting two caps. They are on the same line, but it could be shorting them to ground and causing this. You need to remove it.
von
here is the picture marked with "A" and "B" could you please tell me which one to remove?
Bewertung 0
2 Kommentare:
@touchwireless check the picture I added last.
von
Thank you I will update one I do this
von
Antwort hinzufügen
Touch Wireless wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 712
