Zum Hauptinhalt wechseln
Ein 5-Zoll (12,7 cm), 1,4 kg schwerer persönlicher Exzenterschleifer von Porter-Cable, der 2010 auf den Markt kam.
Why is my sand paper not sticking to the pad?
I recently tried changing my sander paper on my sander pad however the sand paper is no longer sticking. I had left the sander in the garage and it may have gotten a little wet, what do I do to be able to fix this?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi @jpiazza. I am a woodworker number it sounds like you need a new sanding pad or bring the sander inside your house for a day to let it dry out and that goes same for the sand paper since it's hook and loop. My recommendation for storing your sand paper is get a plastic box with a lid and put all your sandpaper inside it so no moisture gets in and now for the sander if you have somewhere you can store your sander facedown so the sanding pad won't get wet you should be set to go and never have to face this issue again. I hope this helps
War diese Antwort hilfreich?
Bewertung 1
If your your sandpaper is not sticking to your sander pad first check the sandpaper and sander pad for debris or moisture buildup. If there is debris take an air compressor to the surface, if there is moisture let it dry. If you see neither moisture or debris buildup it my be time to change the sander pad, a replacement guide can be found here Porter-Cable 382 Schleifteller ersetzen .
Bewertung 0
Antwort hinzufügen
jpfoxracing9 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 19
Letzte 30 Tage: 60
Insgesamt: 9,275
