How do I turn Silent Mode ON to OFF
How do I turn Silent Mode ON to OFF?
Ist dies eine gute Frage?
With the phone in standby, press and hold # on any handset. The phone prompts you to select the number of hours (1 - 9 or Always On) that you want it to stay in silent mode. To confirm press # or wait 5 seconds.
Each handset will display silent mode.
The phone will exit silent mode after the set number of hour or to exit manually press and hold # again.
War diese Antwort hilfreich?
Short & Sweet. Worked great, first time, thank you. Lennie
you're the best. you gave me instructions and within 3 seconds, my problem was solved. thank you so much!!!
Excellent! Have no idea how it got turned on in the first place! Operator error??
You are a genius.
hOW DO YOU PUT IT IN STANDBY?
I was having problems turning off the mute on my mom's Panasonic cordless phone. I cracked the code by holding down the “0” button. You will notice that it has a bell with a line through it. Once you hold it for a few seconds it gives you the option to unmute. Once you unmute, it will immediately go to snooze “ZZzz.” You can then go to Menu and adjust the volume. Whewww…It took me a while to figure it out. I hope this helps.
Thank you I was going crazy over here trying to figure this out thanks for posting this!
Created an account here just to let you know how awesome you are! Lol You're nailed it! Worked like a charm and I spent more time than I should have trying to figure it out! Thank you!!
Thank you so much finally got it off ?
Thank you I had tried all the other fixes and they didn't work but this one did. My boss is going to be happier now thanks again
thank you so much I thought I was gonna get a whooping
Hi @kutzee@aol.com
Here’s a link to the relevant section in the user manual for your model phone, that shows how to access the ringer settings in the menu area.
Make sure that the ringer setting is NOT set to ringer volume OFF but that it is set to either ringer volume low or ringer volume high
add rings to phone 123456
adjust volume of ring 1234
ifixit.com says how to choose how many hours to keep Uniden phone in Silent mode. I don’t want it in silent mode
Hi,
Have you tried pressing the # button to exit (cancel) silent mode?
Yes I have and it didn’t work any other suggestions?
Hi @susanb,
What is the make and model number of the phone if it is not a Uniden D1760?
Unifen5269 won’t come out of silent mode. Doing # doesn’t work
# Dorset work on 5260
Letzte 24 Stunden: 6
Letzte 7 Tage: 35
Letzte 30 Tage: 127
Insgesamt: 83,466
9 Kommentare
when I answer this phone I can hear the caller but they can't hear me?does anyone know how to resolve this issue?Please
von glen johnston
My phone ringer is set to silent. I can't hear it when it rings and I can't figure out how to turn it off.
von teaty pawoo
how do i chab;ge silent mode to off
von e.nichols1956
it did not show any hours
von e.nichols1956
i need more help
von e.nichols1956
4 weitere Kommentare anzeigen
