replacing evarprator fan motor
what do u have to take off in order to do this
Ist dies eine gute Frage?
Step 1: Disconnect the electrical power
Unplug the refrigerator from the wall outlet. If the outlet is hard to get to, shut off the circuit breaker for the refrigerator at the circuit panel.
Step 2: Remove baskets and shelves
Remove all baskets and shelves from the freezer.
Remove the screws from the shelf supports on the right wall of the freezer compartment and remove the supports. Remove the baskets and shelves.
Step 3: Remove the back panel
Using a 1/4" nut driver, remove the screws from the evaporator panel. Pull the right side of the panel forward to remove it. Remove the screws from the evaporator panel. Remove the evaporator panel from the freezer compartment.
Step 4: Remove the fan motor
Remove the mounting clip that secures the fan assembly. Detach the fan blade and disconnect the wire harness. Pull the fan out of the housing.Remove mounting clip for the fan assembly.
Disconnect the wire harness.
Step 5: Install the new fan assembly
Push the wire connector for the new fan into the wire harness. Insert the new fan motor into the housing. Push the fan blade completely onto the fan motor shaft. Replace the mounting clip.
Step 6: Reinstall the back panel
Position the evaporator panel so the screw holes line up. Insert the mounting screws and tighten them securely.
Step 7: Reinstall the shelf supports
Position the shelf rails on the right inside wall of the freezer and reinstall the mounting screws. Overtightening the screws can crack the freezer liner or the mounting rails, so turn the screws until they stop and then snug them up with a final twist.
Step 8: Restore the electrical power
Reinstall the baskets and shelves. Plug the cord in the wall outlet or reset the house circuit breaker to restore electrical power.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 133
tpaulladner what make and model is your device?
von oldturkey03
