Zum Hauptinhalt wechseln
Das Apple iPhone 5s wurde am 10. September 2013 angekündigt. Die Reparatur dieses Geräts ist ähnlich wie bei den Vorgängermodellen und erfordert Schraubendreher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA mit 16, 32 oder 64 GB in silber, gold und space grau.
3530 Fragen Alle anzeigen
Screen assembly- is there differences between different iPhone 5?
Hello!
I was just working with my friends Iphone 5s. I was trying to change the screen assembly, and I think everything went well, but the solution was bad.
Now there is vertical stripe going across whole screen, and when trying the number buttons number 0 is not working.
I took the part from my home, so I don´t know if it was Iphone 5s or another Iphone 5 part. Is there differences between those?
Should I just open the whole thing and but it back (I mean if some of the flex is badly on) or should I change the part to an another?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
It sounds like you have either a damaged digitizer cable, or it is the wrong part. To answer your question, yes, the iPhone 5 display and the iPhone 5s display are different, and an iPhone 5 display will not work in an iPhone 5s. However, to me, your problem sounds more like a damaged digitizer cable. I would just get a new part. Hope this helps.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
aspi91 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 47
