furby moves but will not talk
furby turns on and moves around as well as makes the sound of the motor running , but it will not talk, how can I fix this problem
Ist dies eine gute Frage?
You can check the wire contacts on the speaker and clean them, make sure all the wires are properly connected. If the wires are all connected to your furby/ furby boom, then you need a donor furby boom to swap out the speakers. They sell some pretty cheap broken furbys/Furby booms on ebay, that way the broken furby can use its working speaker in your furby to fix it. Furby and Furby boom's speakers are very similar and same in diameter. If this does not work, then the furby is paralyzed meaning the small 6V brushless DC motor went wrong.. You can replace it with one from a PC DVD reader (this is the door opener motor). Shaft is smaller but it's ok, diameter is good. You need a solder iron as well to replace electronic part from DC motor.
This video may help: https://youtu.be/Xn5a07DFh9k
War diese Antwort hilfreich?
Furby will not speak,tried pressing thru the speaker hole and still no sound. What else can I try, all other functions work ok.Help
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 81
