Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
Charging port replaced now have bad/no reception
Hi,
Recently had my iPhone charging port replaced.
I had unreal download speeds but bad reception for about 30 mins but now my phone struggles to connect to the Internet on 4g and cuts in and out during phone calls?
Wifi works fine though?
I'm stumped.
Is this a cheap/dodgy part that was replaced?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Hi
You have to replace it again because the antenna is on the charging port. Make sure first that you have connected the antenna properly.
Hope this help
War diese Antwort hilfreich?
Bewertung 0
This is caused by the little metal rings on the bottom of the charging port part. These rings connect to the housing which is your antenna.
I’ve bought several of these parts and all of them are missing these metal rings and my clients where complaining about bad reception to.
I’m now using the charging part of a crashed or water damaged iphone 6. No problems so far.
Bewertung 0
I had the same problem after doing this repair myself. I then replaced the original part and the signal was fine again. I checked the original and replacement parts carefully, and they were the same - so I didn't have the missing metal rings issue mentioned above. Next I got a replacement part from a different source (not ebay) fitted that, and all is good. So my experience is it was a faulty part. This seems to be a common problem.
Bewertung 0
Antwort hinzufügen
Trentpacker wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 40
Insgesamt: 4,133
