Zum Hauptinhalt wechseln
Reparatur- und Zerlegungsanleitungen für Garagentorantriebe.
Jerking upon opening garage initially
Lately, when I go to open my garage door, it jerks and then stops. I have to then close it and start again to open it. What could cause it to do this?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
@mactechplus thought you might have some advice on this one.
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
The rollers on the side are binding in the tracks. Track bent? Roller bent?
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Thanks, will have to check if they are bent.
von
Check the rollers on each side, make sure the are not crooked, binding, or other wise. Often the tracks that they run in can get a little tweeted, and this can cause issues, especially where the two pieces meet. Could be binding there.
Bewertung 0
If your door still has a manual lock on it, sometimes the bar can catch on the track as it passes through the curve.
Bewertung 0
Antwort hinzufügen
Wendy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 4,599
