Zum Hauptinhalt wechseln
The Acer Aspire One D270 is a netbook computer with a 10.1-inch display.
blue on light flashing and wont start
my computer wont turn on the blue light just keeps flashing i have tried taking the battery out , pressing the start button. plugging it in without the battery in but nothing , and nothing seems to work. can anyone help please
Ist dies eine gute Frage?
Bewertung 0
5 Kommentare:
im not any boot screen nothing at all just the start light flashing.. thanks
von
same hear, no boot screen. when i turn it on normally, you can see the screen very faintly, starting up. but cannot see cursor to try to do anything before screen shuts down.
von
Same problem please anyone help
von
did anyone find anything
von
Einen Kommentar hinzufügen
1 Antwort
Start your computer up and as soon as the boot screen appears - tap the 'F8' key a couple of times. this will take you to 'Safe Mode' options screen. in safemode its possible to uninstall any program that may have caused an issue, use system restore to an earlier date when all was ok... or make other configurations such as msconfig (entered into run). the start tab on the window allows users to disable suspect programs from starting up at boot.
alternatively:
pressing 'F8' takes you to the 'Safe Mode' options screen, scroll down using the Up and Down arrow keys and select 'Last good configuration', then press 'Enter'. with any luck, it will boot normally from the last good set-up and all you will have to do is re-install a few recent updates.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Sir there is no boot screen power light just flickers and nothing is showing on screen everything i have tried.
von
Antwort hinzufügen
Karen Telkman wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 15
Letzte 30 Tage: 36
Insgesamt: 3,159
