Zum Hauptinhalt wechseln
Modell A1502 / 2,4, 2,6, oder 2,8 GHz Dual-Core Intel Prozessor / Erschienen im Oktober 2013
P5 pentalobe and 1.2 pentalobe screwdriver
Hello,
I am sorry if this is not the correct category for my question but I do not know where else I can ask this.
I am looking for a P5 pentalobe screwdriver because I have to do some fixing on my MBP. In my country it seems there is not P5 pentalobe screwdriver but googling I found out that P5 pentalobe screwdriver's dimension is 1.2 mm; so my question is: is a 1.2 mm pentalobe screwdriver and a P5 pentalobe screwdriver the same?
Thanks.
-C
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 5
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
P sizes TS sizes PL sizes[11] Dimension Usage
P1 TS0 Unknown
P2 TS1 PL1 0.8 mm iPhone 4 (Late), 4S, 5, 5C, 5S, 6, 6 Plus, 6S, 6S Plus
P3 TS2 Unknoen
PL2 0.9 mm Apple Watch Band
P4 TS3 Unknown
PL3 1.1 mm
P5 TS4 PL4 1.2 mm MacBook Air and MacBook Pro with Retina Display
P6 TS5 PL5 1.5 mm MacBook Pro (2009) Battery - 15” only. Also known as Apple specialty tool 922-9101
PL6 1.6 mm
War diese Antwort hilfreich?
Bewertung 17
1 Kommentar:
P5 screwdriver is as the same as 1.2 .You are correct. Had the similar issues before and 1.2 worked for me .Ho fir it
von
Antwort hinzufügen
Carlos wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 11
Letzte 30 Tage: 49
Insgesamt: 28,833
