Zum Hauptinhalt wechseln
The HP Officejet 6500 is a color All-In-One printer. Released in 2003. Model number: CB815A#B1H.
53 Fragen Alle anzeigen
not picking up paper
it's not picking up the paper to print. Mine is a HP inkjet 6500A. The answers I found in this page was for Canon printer. What should I do? If I can't fix it myself, is there a HP inkjet printer repair location in San Antonio?
Ist dies eine gute Frage?
Bewertung 5
1 Kommentar
there is a gear that breaks that drives the paper pickup rollers. the gear actually splits. i have glued it on the shaft and works fine. Its just a really big messy job
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Estimado yo tambien tenia el mismo problema, la falla era en uno de los engranajes de el sistema de alimentacion de papel , lo pegue y se soluciono . Te puedo mandar fotos del engranaje
Espero te pueda servir
https://drive.google.com/open?id=0B4Wwlw...
en la imagen puse un espejo desde la bandeja para poder mostrar el engranaje .
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Explica mejor como es que lo pegaste y como lograste llegar hasta ese engranaje
von
Here is a translation, thx to Google translate
Dear I also had the same problem, the fault was in one of the gears of the paper feed system, paste it and solve. Can I send you photos of the gear?
I hope I can serve you
von
I glued it and it lasted 3 prints. I believe the heavy photo paper took a toll. I am now looking for a top feeder. Any suggestions?
Bewertung 0
Antwort hinzufügen
Genx Ed wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 2,503
