How to fix the E4 error?
When I turn on the rice cooker, the panel flashing E4 and it could not operate.
Ist dies eine gute Frage?
What model is the rice cooker? Is it a pressure cooker? Did it come with a manual? Usually the error codes are in the back of the manual or you can search them online.
I did find this:
http://www.manualslib.com/manual/265330/...
Doesn't look good.
War diese Antwort hilfreich?
What type of electronic malfunction? Heater element, thermal sensor or others?
For Philips rice cooker model HD4515/60.
https://www.philips.com.sg/c-t/XC0000179...
This should help...
You need to check the cable that connect the sensor inside the head of the lid. Usually it's break, you just need to reconnect and solder the cable and done
Letzte 24 Stunden: 2
Letzte 7 Tage: 36
Letzte 30 Tage: 137
Insgesamt: 18,603
von LeeSL
von LeeSL
