No red light - no power at all.
Suddenly our TV won't turn on. The red light that is normally on when the TV is off is also not on.
Ist dies eine gute Frage?
War diese Antwort hilfreich?
the stanby light shows on my tv but doesnt work, i try to turn on and nothing happens ...
You are a lifesaver- thank you!!! :D
The red light shows on the TV but the TV is not powering on
Does your TV have a power switch? Most TVs do, but sometimes - as with the Sony Bravias - it isn't easy to find. It can easily be switched off accidentally.
my tv was dead unplugged it for a half hr like you suggested and its back on ! thank you lots
Power within TVs in general has 2 forms (for lack of a better way to describe it).
1) Standby power - This is usually 5V and is there to respond to a remote. The presence of this is known by a red light that is seen from the front of the TV. If this is not present, a remote won't work and most likely the TV won't turn on at all. (This is what is being reported here.)
2) Running power - This is what is used once the set turns on. This is triggered either by pressing the power button on the TV or on the remote. In both cases, the internal "computer" is told to turn on the TV. Problems with this power supply usually result in the set clicking on and then off, no picture but sound etc.
Since the reported problem here is no red light at all, I would be looking for a more obvious problem with the power supply board. For example: a blown fuse, a defective rectifier diode in the standby circuit etc.
Further investigation is required to determine the exact problem. If you are not comfortable working on electronic devices, seek a professional service shop for help.
Dan
My Sony TV has No stanby light and not working ..
External power adapter is good..
But Tv not working
KDL-40W650D (MODEL)
Standby LED not working after system update???
I have a Sony XBR-43X830C There is No standby light and the screen stays off when i try to power on the tv from the buttons on the back of the tv or the remote. I have tried following every tutorial i could find(holding the power button and volume down for 30 seconds then plugging or unplugging tv) i have tried every theory... I have also used a multimeter to check for power on the fuses and diodes and dif places throughout the circuit boards inside the tv. Not sure what I should look for.. Please help
Letzte 24 Stunden: 14
Letzte 7 Tage: 97
Letzte 30 Tage: 402
Insgesamt: 156,694
30 Kommentare
Rebecca Chock what is the exact model number of your TV? what have you checked? Have you tried a different power outlet?
von oldturkey03
My TV model number is KD-75XE94xx have checked my power socket with other device and it works fine but my Sony TV ain't showing any red light power indication at all when plugged
von Teebash
I have the same problem. My model code is UA40H5500AKXXA no power and no red light
von lEBOHANG bULANE
I have same problem tv model is
PS59D550C1M
von Melissa Rutherford
@meljay what problem do you have with your TV? what have you tried to fix it?
von oldturkey03
25 weitere Kommentare anzeigen
