Why coes my iPod Classic go down when not used.
If my iPod Classic sits without playing for over about 15 minutes, it crashes and I have to do a hard reset to use it. It is really annoying as every time I do to use it, I must first hard reset. The problem does not occur if it is playing, only when it sits idle without playing. I have replaced the battery, but the problem is still there.
Ist dies eine gute Frage?
That problem won't have anything to do with the battery...
von ETHREAL1
What happens when you don't let it sleep?/does it crash when the screen turns off or just after some amount of time?
von ETHREAL1
It will play continuously with no problem. If it sits idle, the longer it sits without the screen, the more likely the crash. Also I have to check that it not crashed when I go the recharge it or it will not charge.
von mark
What version of the ipod is it? 5th gen or 6th gen? Did you run a diagnostic test on it? Did it pass the headphone test (HP)? Some earlier circuit boards aren't compatible with larger drives.
von Chi
Other than it crashing when not being played, everything functions normally. The upgrades have not affected the problem.
von mark
