Zum Hauptinhalt wechseln
The ZenFone 5 is a 6.2" smartphone made by Asus, released in May 2018. The phone has two rear-facing cameras and comes in Meteor Silver and Midnight Blue.
18 Fragen Alle anzeigen
After replace display, Asus zenfone 5 stays on only with power cable
Hello everyone! Sorry for my english :)
I have a asus zenfone 5 who fell and as a result has cracked the glass. I bought a kit for the replacement of the display and yesterday I replaced it.
The display works perfectly but there is a problem: the phone turns on only when I plug in the power cable and goes out as soon as I remove the cable. Once you turned on the phone the power and volume buttons works and the battery is detected and appears to be in charge, but without the power cable the phone is not working. I also tried to disconnect the connector that connects the battery to the phone and the phone still comes on connecting the power cable, however, does not detect the battery.
What can it be? Should I try to replace the battery? Or is it more likely that damage has a connector (does not seem to have broken anything).
It 's really weird because when the phone is connected it works and it is in charge.
Thank you
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
check the battery flex cable or measure the battery voltage with a multimeter
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Miriam baraldi wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 6
Insgesamt: 430
