Zum Hauptinhalt wechseln
The Zebra GK420d is a direct thermal label printer for desktop use.
3 Fragen Alle anzeigen
zebra gk420d printer indicator light flashes red and green
zebra GK420d printer indicator light flashes red and green and printer does not print
is there a reset button or what would be the fault?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
Error 8 Alternate Green Red FLASH memory is not programmed.
Return the printer to an authorized reseller.
Error 9 Red and Red Green The printhead or motor has had a critical failure.
Status Indicator Reference
A complete list of status light indicators for the GK series printers can be found here:
https://km.zebra.com/kb/index?page=conte...
War diese Antwort hilfreich?
Bewertung 4
Thank you, with your help I was managed to repair my gk420d. Fixed the rfid lamp.
Morten
Bewertung 0
4 Kommentare:
Can you explain how you solved it? Many thanks
von
Morten, can you give details of your fix?
Thx
von
Morten can you please explain how you fixed the rfid lamp?
von
Good evening!
The flash memory S29AL032 has inconsistent data, you must unsolder the memory, erase, program and resolder on the main board.It is service for technicians.
von
Please give details I have the same problem
Bewertung 0
Please delete this thread from the internet immediately since the unhelpful information it contains keeps coming up in my google searches!!! PLEASE DO THIS IMMEDIATELY!!!!
Bewertung 0
Antwort hinzufügen
brian wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 24
Letzte 30 Tage: 117
Insgesamt: 19,206
