Zum Hauptinhalt wechseln
Erschienen im Juni 2014, zu identifizieren anhand der Modellnummer B051.
How to put black leather around beats headphones
The leather on my Beats By Dre Solo2s are coming off. It is not the actual ear cushion though that is falling off. It is basically tucked in under the ear cup. Is there any way to re tuck it underneath the earcup?
Thanks for your advice
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 17
41 Kommentare
How would one go about re-gluing the ear cushion? The leather on my ear cushion has separated at the seem on the inner-perimeter of the ear pad (you can see the edge where it is 2 separate pieces of leather bound together). Any suggestions would be a great help!
von
You can use a credit card to push it back into the groove it's come out from. Works perfectly
von
This worked perfectly for me. Thanks!
von
Great solve. Thanks!
von
You saved me!! Thank you!!
von
36 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
7 Antworten
Gewählte Lösung
If you still have this problem, just grab a debit card or any kind of card as long as the card is strong and will not rip/break on you, and just tuck the leather into the "slot"
I personally do not like to damage the device by adding glue because adding things can ruin the headset itself so I would rather have to re tuck and have the headset good as new than use other items and ruin it.
War diese Antwort hilfreich?
Bewertung 52
31 Kommentare:
This was so helpful, thank you!!!
von
worked like a charm. i was so worried I'd have to waste time going into apple store. thanks!
von
this was so helpful thanks! i used a gift card which was a little thinner and easier than a credit car
von
Follow Mike's advice above to use a card!!
von
von
26 weitere Kommentare anzeigen
Completely remove the cushion from the headset. Then squeeze foam add super glue to the edges, put edge of leather to the super glue, then hold it or tape it down till the glue sets.
Bewertung 2
1 Kommentar:
If you don't want to use glue, look at Mike's response!
von
The Credit Card is a good temporary hold for the slowing drifting leather but if you want a permeant fix id advise watching this video, i did and followed the advice and now my beats look impeccable.https://www.youtube.com/watch?v=o57sTtr8...
Bewertung 0
use any type of card but has to be strong enough not to snap just push the ear pad back into the headphone with the card
Bewertung 0
1 Kommentar:
Tucking works but not for long. Very disappointed in quality of such an expensive set of headphones.
von
Are there any new cushioning than can be purchased to replace the existing one’s? I pushed it back but it’s temporary and it keeps coming out and it looks tacky
Bewertung 0
Follow the instructions from this video
https://youtu.be/mVTXCghufV4
Bewertung 0
I suggest you to buy ear pads replacement for beats headphones from beatskin store because you will get a detailed tutorial on how to replace them and a repair kit too. Here you will find ear pads for any beats headphone model https://beatskinstore.com/product-catego...
Bewertung 0
Antwort hinzufügen
zaydnavaz wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 45
Insgesamt: 137,157
