MacBook Pro Is Prone to Condensation!
All right Fellows, I am just sharing my experience about this problem, although I found a lot of complains about it on the web, there may still be someone trying to figure it out what happened to their mac.
All of the sudden my macbook pro didn’t turn on, being located in Brazil, and having to deal with an Apple authorized repair shop with horrible costumers reviews, I decided to open it up and try to have a clue of what was happening, and there it was, signs of humidity on the logic board.
For the fact that I am sure no spill was in question and there were also greenish like mold areas on the board, I knew I was looking at a chronic problem, to be more specific, a condensation problem that had been occurring for quite sometime. I have been living in the south of Brazil (where it is humid and gets cold in the winter months) for one year or so, but that should not be a reason for this kind of problem.
So, after searching the web for a while, I learned that I should remove and clean the logic board with isopropyl alcohol and a toothbrush, so I did it.
I was able to revive my mac but, just yesterday the same problem occurred again, and I followed the same procedure with the same result, Thanks God!
My humble conclusion is that, the Macbook Pro (mine is a 13” mid 2012) is prone to condensation due to its very high operating temperatures (hot air holds more moisture than cold air) caused by its enclosure and low rpm exhaust, plus, its cold aluminum unibody, making a perfect place for condensation to be created.
It is a shame Apple is sacrificing durability over design and quietness. They refused to address the problem and claimed it was due to liquid damage done by a spillage.
I don't mind paying a higher price for something but, I also expect that something to make it worth it. Unfortunately Apple thinks durability is not part of quality!
P.S.: As of right now, system is using about 60% of the CPU, that should be happening because at this time, I only cleaned the logic board from its underside, without removing it from its place. The same happened before, when I had kernel task taking about 90% of the CPU, before I took the logic board out for a complete clean up. The computer restarting by itself is another symptom of this problem.
If anyone would have any idea of how to avoid this problem from coming back, please let me know. I have been keeping my mac inside a closed case, together with a sock full of uncooked rice and a bag of desiccant, and already have macs fan control app set at 35 to 65 Cº.
Ist dies eine gute Frage?
11 Kommentare
Omg! My computer died a few months ago and I was told it was water damage!!! Which is IMPOSIBLE because it never happened and I'm the only one how get near it. I fought, and cry and yell at apple care and they chance de motherboard with no cost. I have always love the custom service on apple, that's the only reason I keep using it, buy the never told me this problem. I even bring up the theory on condensation, because it was the only possible thing, and they told me.. NO WAY! That never happens. This is crazy. So happy to find this by mistake
von rossbaqueiro
We took a family vacation to Costa Rica in late October/early November, just towards the end of the rainy season. Temperatures were high 20's Celcius, and it rained at least 30% of every day, so humidity was very high - likely around the 90% range. The condo we stayed in did not have air conditioning. By day 2 or 3 of our trip, both my Macbook Pro and my daughter's (both 13" mid-2012 models) stopped working. Hers had the screen flashing and turning black and the track pad acting erratic (so we just shut it off to prevent damage), mine wouldn't even turn on. We thought they were both fried for good. However, our last night in CR, we stayed in an air conditioned hotel prior to flying home to Canada. Within about 3 hours of being in the dry environment provided by A/C, both laptops were back up and running fine - no future problems whatsoever.
von pat
Exactly what I face with my device in Germany. There is no window in the bath room and my ex-girlfriend took long-lasting showers, so the humidity was quite high at the time she stayed at my appartment.
After I took off the bottom plate, I saw water drops "inside" the laptop. I NEVER spilled ANYTHING on the MBP and it died 20 days after the 1 year warranty.
It's just bullshit what Apple did here. Will try to fix it by myself - Apple rejects warranty (even if the water indicators are colored green).
Does your MBP still work?
von Martin Pfeffer
I have this same issue. Just moved to a house close to the beach, and the humidity and salt air are definitely the cause. Every time I bring the MacBook into the Apple store it starts working again because of the AC and low humidity.They checked it out and everything hardware is perfectly fine with no water damage whatsoever. It is a shame Apple has no resolution and are not even aware of this issue. My only option is to buy a new laptop and hope the newer MacBooks don’t have this issue.
von Daniel Szenczy
Same issue here...macbook air early 2015 model. Over a period of 2 to 3 days, it used to get unusually heated up( first warning) then one fine day ..RIP. Went to apple service centre and was told its fungus attack and it had apparantly short circuited few components. Since Apple has a wonderful policy of Only Replace No Repair, cost of MLB replace will be $750. Why so despite being in warranty? Because it is a case under liquid damage. I fought with Apple guys over a month and finally they gave in. They replaced my MLB under a special exception case. Case closed but the ghost has haunted recently until I decided to bury the mac.
Questions: Apple has this issue with early 2015 editions and prior, why doesnt it acknowledges it and declare a recall. In a way it is complete fraud and cheating of customers.
von Gautam roy
6 weitere Kommentare anzeigen
