Dryer not getting hot
How to fix dryer that isn't getting hot
Ist dies eine gute Frage?
Thermal Fuse
The thermal fuse is a safety device designed to protect the dryer from overheating. The fuse is located on the blower housing or at the dryer’s heat source such as the heating element on electric dryers or at the burner on gas models. The fuse should be closed for continuity meaning it has a continuous electrical path through it when good. If overheated the fuse will have no continuity meaning the electrical path is broken and the fuse has blown out. A multimeter can be used to test it for continuity. Be aware that a blown thermal fuse is an indication of a restricted exhaust vent from the dryer to the outside. Always check the dryer venting when replacing a blown thermal fuse.
War diese Antwort hilfreich?
My NEW stackable washer/Dryer lights just blinks and won’t start. When I press the start button it beeps three times. I’ve only had this unit for two months.
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 23
Insgesamt: 9,034
3 Kommentare
My stackable dryer will spin but not getting hot
von Kamisia mckenzie
Kamisia please start a new question and give us your make and model number
von mayer
What would cause my dryer not to heat up and not cycle? The knob doesn't turn to shut it off automatically
von Kenneth Williams
