Zum Hauptinhalt wechseln
Why does my freezer work for a short spell then stop freezing?
I have a super general freezer, which ddespite its compressor being replaced several times has still failed to freezr foodstuffs . Whenever I have had it replaced it has only worked for a couple of months and broken down again.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Was this problem solved? My freezer is not working after a month of working. has happened three times now. What was the issue in your case?
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Cause 1
Condenser Coils are Dirty
The condenser coils are usually located under the refrigerator. They dissipate heat as refrigerant passes through them. If the condenser coils are dirty, they won’t dissipate the heat effectively. As debris builds up on the coils, the refrigerator becomes less efficient, causing the refrigerator to work harder to cool down. If the coils are significantly dirty, the refrigerator will not be able to maintain the proper temperature. Check the condenser coils to determine if they are dirty—if the condenser coils are dirty, clean them.
Evaporator Fan Motor
The evaporator fan motor draws air over the evaporator (cooling) coils and circulates it throughout the refrigerator and freezer compartments. Some refrigerators have more than one evaporator fan motor. On refrigerators with only one evaporator, the evaporator is located in the freezer compartment. If the evaporator fan is not working, it will not circulate the cold air to the refrigerator compartment. If this occurs, the freezer may still get cold, while the refrigerator will not get cold. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor.
Cause 3
Condenser Fan Motor
The condenser fan motor draws air though the condenser coils and over the compressor. If the condenser fan motor is not working properly, the refrigerator won’t cool properly. To determine if the fan motor is defective, first check the fan blade for obstructions. Next, try turning the fan motor blade by hand. If the blade does not spin freely, replace the condenser fan motor. If no obstructions are present and the fan blade spins freely, use a multimeter to test the fan motor for continuity. If the condenser fan motor does not have continuity, replace it.
Cause 4
Start Relay
The start relay provides power to the compressor. If the start relay isn’t working properly, the compressor may run intermittently or may not run at all. If the compressor won’t run, the freezer will not cool. To determine if the start relay is defective, unplug the freezer and remove the start relay from the compressor. Use a multimeter to test the start relay for continuity between the start and run terminals. If the start relay does not have continuity, or if it smells burnt, replace it.
War diese Antwort hilfreich?
Bewertung 6
5 Kommentare:
I forgot to include the fact that it is a chest deep freezer. Does that make a difference since I noticed in your answer you refer to refrigerator?
von
Not really they work the same. But I added the start relay.
von
Thank you so much for the answer.
von
Very well informed. Thank you
von
Nice answy👍
von
Your problem could also boil down to a leak in the sealed system. I'm referring to the evaporator or condenser coil or connecting tubing. This system carries the Freon to and from the compressor.
Many chest freezers have the evaporator coil built into the cabinet walls of the freezer itself making it next to impossible to find and repair a leak in the evaporator.
Leaks in the condenser are quite rare but they do happen. They can be repaired if they can be accessed.
Connecting tubing to all these components can also leak Freon. You'll want to check for leaks on all this tubing.
If you've have several compressor change outs and find the system still doesn't work properly -- I'd be looking for a Freon leak.
With all your compressor change outs you could be looking at the possibility of a sealed system that's contaminated. If this is the case it will need to be carefully cleaned and cleared of debris. It's a difficult process.
Servicing the sealed system, working with Freon, the proper reclamation of Freon and the safe handling of Freon require proper licenses. Make certain you dela with people who are proper licensed and know what they are doing.
Bewertung 0
Antwort hinzufügen
Stephen Mulira wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 27
Letzte 30 Tage: 128
Insgesamt: 17,068
