Zum Hauptinhalt wechseln
Repair and troubleshooting information for the HP Pavilion dv6000, an HP laptop part of the HP Pavilion series. Released in April 2007.
a black screen and it says my operating system is not found
how do I fix this. I have a black screen and i can hear it booting up but get nothing everyonce in a while I get the screen where I can enter the boot menu or change it but thats it. Ive tried everything reset cmos to taking out the hard drive and still nothing not even anything on an external monitor. help me I dont care if I have to go over the steps a second time Im so willing to try any process
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Surendra Singh
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Lori Ubrisk, I am a bit confused by your question. You said that is "says my operating system is not found" which would be a hard drive issue, but then you say that your screen stays black and does not display anything. that is a GPU issue for which this model is well know for. Sometimes a reball can fix it, other times you may need a new logic board. Here is my answer to a will not power on :" This is a well documented prob with this series of notebooks and if you do a search on the Internet you'll find lots and lots of unhappy and frustrated people. The problem is the motherboard, and the symptoms include loss of bootup, VERY slow bootup, WiFi stops working, etc. is simply that the MOBO board overheats and fries the video driver chip. The cooling design of this PC is inadequate.
You might try this to verify.
1. Attach an external monitor, see if that shows anything.
If not then:
1. Take the battery out and unplug the charger
2. With the computer lights OFF, press and hold down the power button for 15 seconds
3. Plug the charger back in and start-up the computer
Let us know what you find.
War diese Antwort hilfreich?
Bewertung 4
1 Kommentar:
Hi, I made all with your recommendations, but after unplugging charger and holding 15 sec the comp is dead at all! HELP!
von
Antwort hinzufügen
Lori Ubrick wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 33
Insgesamt: 343
