Zum Hauptinhalt wechseln
Mower cuts out when I pull arms in to go àny where
When i start the mower and try and stary mowing it cuts out
Ist dies eine gute Frage?
Bewertung 1
3 Kommentare
Wow, Not only is this cryptic but what do you mean by pulling arms in. Many mowers require the operator to hold a latch or lever for the mower to continue running. If you take you hand off of the lever or handle the mower is supposed to turn off.
von
Brian...On Zero Turns, You pull in the arms to move...lol
von
@fred1 what exact model is your mower?
von
Einen Kommentar hinzufügen
5 Antworten
Hilfreichste Antwort
This is most likely a safety switch issue. Usually the seat safety switch will cause this problem. The mower dies because it thinks nobody is sitting in the seat, and shuts off for safety reasons. I have read this mower also has issues with the rollover safety switch (shuts off mower if it thinks it has rolled over).
Check out this forum for more information:
http://www.lawnsite.com/threads/toro-saf...
War diese Antwort hilfreich?
Bewertung 3
I had the same issue. I could not find an answer online, and even chatting with Husqvarna tech support was no help, so hopefully this will help someone else. When sitting on the seat with both levers fully out to the park position, my mower engine would start and the blade would engage when pulling the blade engage switch like normal. I believe that if you are not sitting on the seat, the mower will not engage. So if you are sitting on the seat and the engine is running, and activate the mower blades and they come on, your seat switch is good. On mine, when I moved the levers from park to neutral, the engine would shut off, just like the key switch was turned off. What I found is that I had a sticking park lever switch. If both lever switches are working properly, moving either lever switch from park to neutral individually will kill the engine. If you move both levers at the same time, then engine will keep running. One of my switches was stuck, so it always thought that one side was in park. When I moved both levers, it thought I only moved one lever and shut off the engine. If you can move the lever on one side from park to neutral and the engine stays running, that is your sticking switch because it is still being made as if it were still in park.
Bewertung 3
3 Kommentare:
This was very helpful. Found my right switch was the issue.
von
it shuts off with either or both levers
von
I have the same issue. Engine dies everytime parking brake is released. I removed the seat wiring from the switch, cleaned and plugged it back. Problem solved.
von
When I put the mower in gear it shut off
Bewertung 0
What can cause a mower to shut off when you put it in gear it is a carsman mower
Bewertung 0
i replace both safety switch pulled the arms in and it still cut off zero turn
Bewertung 0
Antwort hinzufügen
Pat Mills wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 33
Letzte 7 Tage: 235
Letzte 30 Tage: 1,133
Insgesamt: 24,547
