"No service" after replacing battery
I replaced original with 1600 mAh and lost the aerial signal the next day.
It works when in certain areas only.
I tried reset network and restore of system.
I tried disabling 3G and it would work intermittently.
Any ideas?
Update
How to fix the Iphone 3GS " NO SERVICE"?
Update
I had problems connecting #7 and had to tape it down as it wouldn't lock. I will take a look with a magnifying glass and try to correct the connector.
There is a pointed piece beside #7. Should it come in contact with the metal casing?
I have sporadic service in selected areas of Toronto (such as near Rogers head office).
When i installed the battery, i noticed the "do not remove" paper had been removed and re-attached and the #7 clip didn't reconnect easily.
I have a feeling the phone was reconditioned and not new when received.
Ist dies eine gute Frage?
tiffanyharville. you asked a question in the answer section of a question that was asked 4 month ago. You question shows up as an answer, if you truly need help , erases this question here and post is as a NEW QUESTION.
von oldturkey03
