Zum Hauptinhalt wechseln
The second generation HTC One—dubbed the HTC One (M8)—features a dual flash and the new Sense 6 UI, and was released March 25, 2014.
Earpiece replacements ALWAYS CRACKLING top speaker
hi, i've got about 5 HTC One M8's and all 5 of them have been refurbished, the earpieces were damaged & replaced and each one in all 5 phones is crackly even at low volume, ive spent near £40 on new pieces to no luck, its as though the "driver" is touching the frame or something else within...
ive spent hours studying it, "experimenting" from frame cutting to earpiece module cutting.. i cant afford this no more
the repair shops say they have fixed it but it comes back worse than i gave it them..
i have a genuine used M8 which the earpiece was perfect but had a spungey like adhesive, of which every replacement doesnt have, instead a tape like sticky
now then, how the F do i get them not to crackle, is it because it needs a cushion "foam adhesive" between the frame or simply just a secure gap from the frame...
the sticky tape adhesive when fitted only induces poor sound and crackling
it only seems to be the top speaker as the bottom one has a housing shell prebuilt into it.. it never seems crackly
also there is a soundtrack i found of which the crackling is very audible though most phone can handle the track, link below
https://www.youtube.com/watch?v=YIY8aKg4...
any help appreciated whatsoever...
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
I believe there is a problem if the phone is playing music with BoomSound on and then a call comes in, it can screw with the earpiece settings. Try turning off BoomSound and then reboot the phone.
War diese Antwort hilfreich?
Bewertung 0
Did you get a proper solution to this problem? I'm facing the same issue and it's very annoying since I otherwise love the smartphone and really want to keep it.
The problem started when my repair guy replaced the battery and he has since tried 3 different speakers and they all crackle and distort the sound :(
Cheers
Bewertung 0
Antwort hinzufügen
Latios Eon wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 733
