Zum Hauptinhalt wechseln
Das iPhone 6 Plus mit dem 5,5 Zoll Display ist die größere Version des iPhone 6 und seit dem 19. September 2014 auf dem Markt.
1525 Fragen Alle anzeigen
no service/searching after screen and antennae replacement?!
had screen replaced and antennae replaced (charger port flex) now searching and no service 90% of the time. Tried reset network settings and battery pull and reconnecting antennae. Please help! Thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
Does the iPhone 6 Plus still display an IMEI number in Settings > General > About phone?
(And as always, don't post IMEI number in here as it uniquely identifies your phone)
von
Yes it does.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
This is a belated answer so hopefully it can be of use to folks who search for and find this question.
After you have eliminated antennae or network locks as the possible culprit, searching issues on the iPhone 6 are usually related to the baseband IC. The baseband IC is very sensitive, just like the Touch IC's on the 6 Plus; it also suffers from poor quality traces and pads.
Go to your phone’s dialing keypad and dial *#06#. You should see the IMEI displayed.
If the IMEI is not displayed, the Baseband IC has to be reballed and two small copper traces (U1/V1) have to be rebuilt and solidified. This is commonly referred to as the “long jumper” solution. You can check out this answer (Service is "Searching" indefinitely) (by @teetopp) as it summarizes the issue really well.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Austin Harris wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 140
