alot of smoke from tailpipe
This truck has been in tow yard for almost 2 years. Besides alot of smoke from tailpipe what possible other repairs should be done
Ist dies eine gute Frage?
First off what color is the smoke?? You may have blown head gasket. Below I'll list what you should do/change
Spark plugs
Wires
Coil pack
Fuel filter
Pvc valve
Clean or replace egr valve
Change belts (dry rot possible)
Change oil
Flush radiator
Change upper lower rad hoses (again dry rot)
Have transmission flushed
Run 2 tanks of premium gas with fuel system cleaner through good fuel system cleaner seafoam
That's really a good place to start a car sitting that long does more bad than driving 30 thousand miles also check tires for dry rot
If ya need any other help reach out thanks
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 73
1 Kommentar
What color is the smoke?
von mayer
