Zum Hauptinhalt wechseln
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s Plus gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
1041 Fragen Alle anzeigen
Touch ic problems iPhone 6plus
So i got a iPhone 6 plus today with the grey bar on top indicating that the touch ic was going bad, or not soldered well. i have replaced the cumulus chip and now i have no grey bar, but the touch is a little less responsive near the letter U if you were texting. or trying to slide backlight brighter 3/4 of the way it stops.
Do you think this is a problem with the chip i replaced or is this caused by the mason chip?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Is the screen that is on the phone right now have any signs of physical damage at all?
von
Einen Kommentar hinzufügen
2 Antworten
Screen could possibly been replaced. It is known to happen that the Touch ID will stop working once a screen is replaced. Part of the deal made when the lawsuit happened over Error 53 (source: TechCrunch).
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
The reason the Touch ID isn't working after the screen replacement is only because of two reasons;
1. the home button was damaged during the repair.
2. the home button flex cable was damaged during the repair.
I saw it happened only was when the Touch ID stopped working after a repair for no reason on an iPhone 5S and after I reset all the settings (in settings) it was fully working again.
von
first of all try to install a new screen to see if it helps. there is no harm in trying a new screen.
if it didn't help any, try re-soldering the chip back in the place, maybe you missed something while soldering the IC. if yet it's not solved then I think it safe enough to say that It is indeed the touch IC.
Bewertung 0
Antwort hinzufügen
Jessica Ward wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 1,063
