My phone keeps turning off
My phone turned off by itself and then didn't turn back on. I removed the battery and let it sit for a while and then put it back on and still didn't turn on. After morr than one hour and half it turned on but later in thr night it did the same. Then I did a Reset using Recovery Booting. The next day it turned off again but after 10 minutes Iit turned on back and now it did the same and doesn't turn on. It turns of till I see the Samsung logo and then it turns off and on again just to see the Samsung logo. And when it worked after I did the reset I went to the software upgrade and it said that my opersting system has been modificated in an unauthorizate way. Does anyone knows what the problem might be?
Ist dies eine gute Frage?
2 Kommentare
I have Samsung Note 4 SM-N910G & I am having same problem. Shutdown anytime.
1) Replaced battery...doesn't work.
2) Try two new original battery......doesn't work.
3) Installed Wake Lock.....doesn't work.
4) Update ROM.....doesn't work.
5) Root phone....doesn't work.
6) Hard reset from TWRP......doesn't work.
7)Clear everything from TWRP......doesn't work.
8)Format mobile complitely.....doesn't work.
9) Custom ROM Lineage.......doesn't work.
Still crash any time without any reason. Shut down automatically even seating on table.
Please help me if anyone know solution.
von Nehal Chavda
You haven't by chance replaced the battery lately? I have had 2 phones do similar things after replacing the batteries. Once was a Samsung 5 and the other a Samsung 6. One would turn off even though it showed a charge in the 80% range and would continually reboot once it go to the samsung logo. I found by plugging it in...once it showed charging I could power it on....but typically I would have to leave the cord connected. Since everything is glued these days it's kind of hard to open it back up to check out the cabling. I should also state the issue happened a few months after the battery was swapped and not right away
von Brian Reid
