Zum Hauptinhalt wechseln
The PSP 3000 was released in the U.S. on the 15th of October 2008.
92 Fragen Alle anzeigen
Is the PSP 3000 motherboard Hot-Swappable?
I recently tried to update my psp firmware, though,at the time, I had lost my battery cover. As you would expect, my battery popped out and there we got a full brick!
Anyways, I read on a forum that changing your motherboaard fixes the brick(?), and I was wondering if the PSP's motherboard fixes the problem, and if it does, is it hot-swappable or is there a device key bound with the rest of the system?
Thanks in advance, Chrysostomos
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
the motherboard is not hot-swappable. you can swap it though for the same one working...
http://www.youtube.com/watch?v=t7sWU1bzd...
this could prove cheaper...
i cannot tell you, if it works so please take it as without guarantee..
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Thanks man I will try! You really saved me some bucks there! I was just about to order a motherboard! I will try the pandora- magic mem stick way. And if it does't work, np its just like 30 bucks! In the end I can just send it for repair!
von
Also I think you confused "hot-swapping" with swapping. Hot-swapping means you can remove and replace a component without having to power the system down.
Bewertung 0
Hi. Pandora battery can't be used to unbrick psp3000.
Bewertung 0
1 Kommentar:
...No, as the Brite 3000, being "different", will not accept a Pandora Battery, and it just BRICKS IT MORE!!! And that's what you DON'T want.
--Sent from my Raspberry Pi 3 using Chromium 51
von
Bro if you not break it with cfw and the damaged from you buy motherboard… If The psp not damaged and only cfw break system you can see youtube to unbreak psp 3000 easy…
Bewertung 0
Antwort hinzufügen
Chrysostomos wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 3,458
