Zum Hauptinhalt wechseln
Released in May 2014, the Chromebook 2 features an 11.6" display, Intel Celeron processor, and a 16GB SSD. Identified by model number XE500C12-K01US.
15 Fragen Alle anzeigen
Can the charging circuit on the Chromebook xe500c12 be replaced?
The charger died, and in the process of trying to retrofit a charger I seem to have damaged the device. Now that i have a new replacement charger, there is no light when the charger is plugged in, and the device does not charge.
Can the device be fixed? Could it be the charging circuit? Can anything be replaced?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
It depends. Perhaps check all the capacitors and other parts for shorts, then it looks like you might have to track down a replacement PMIC of some sort and solder it in. Do you have a picture of the board?
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Noel Arnold wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 135
