Zum Hauptinhalt wechseln
1,83 GHz Core Duo oder 1,83, 2 oder 2,16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
201 Fragen Alle anzeigen
Green lines display in video and freezes frequently.
When video is played, or ichat is used green horizontal lines jump across the screen. Many times when using dashboard or switching to another app, the computer freezes and requires a reboot. This happens 5-10 times a day.
I'm thinking video card. Can you help?
Thanks,
David George
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Definitely sounds like a GPU problem. Check your computer to make sure it is not overheating. Overheating will cause the GPU chip soldering to develop fractures. Unfortunately there is no easy fix to this, you will have to get the GPU soldering reflowed or better yet reballed. But you must fix the overheating issues first or the problem will just keep coming back.
War diese Antwort hilfreich?
Bewertung 0
I had this problem for a long time. In general smcFanControl software helps. It let's you speed up the fans to a point when the GPU is no longer overheating and the artifacts and freezes no longer happen.
Bewertung 0
Antwort hinzufügen
David George wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 1,483
